E Odin Scheinwerfer
Zimmermännche
Roller: E Odin 10kw Typ2
PLZ: 555
Re: E Odin Scheinwerfer
Beitrag von Zimmermännche »
Miguello80 hat geschrieben:
Fr 4. Okt 2024, 22:39
Yeah, I spent hours on Internet till I found those autogamma lights. On Aliexpress there were some 2" lights too but I chose seller from Poland in case of problem with them.
Lights from your links are fog lights, ok, first one has some "high" and "low" power and sure, it will not be worse than factory lights, but you will have to manage how to mount them and all you will get will be another flashlight so why waste time with those lights when you can have real lights for around 100 euro incl. shipping ? I do not force you into autogamma, do whatever you want, I just do not get it.
Ich hatte mir deinen Link ja auch angeschaut, polnisch verstehe ich aber nicht und ich habe auch keine Funktion der Seite zum umstellen der Sprache gefunden, damit auch keine Informationen zu Zahlungsmöglichkeiten und zu "Lieferregionen".
Ich habe auch die Seite autogamna Berlin gefunden, diese ist aber im Aufbau und ohne "Verkauft".
Deshalb hatte ich gesucht was ich so auf meinen "Standardportalen" finde.
E-Odin 3.0S 12/2022
Miguello80
Roller: E-Odin 2.0 6kW AMR
Land: anderes Land
Beitrag von Miguello80 »
Zimmermännche hat geschrieben:
Sa 5. Okt 2024, 09:56
Ok, so translation problem...
When I open this page in Opera GX browser, it offers automatic translation of whole page using Google Translator.
It does not do it on this page so I thought it is implemented in webshop... I just added the Google Translator add-on but it does not work as I am used to from Firefox, I have to figure it out.
In Firefox I have Google Translate Element add-on that allows me to switch whole page / web into another language (this I use for this forum, easier than copy paste into translator, only for reply/answer I have to use non-translated page).
Autogamma uses chat box so during work hours you can ask directly. Or via Facebook (https://www.facebook.com/Autogammasklep) or e-mail sklep@autogamma.pl.
In case I can help you, do not hesitate to ask.
Zuletzt geändert von Miguello80 am Mi 9. Okt 2024, 23:59, insgesamt 1-mal geändert.
jeff-jordan
Roller: Classico LI & Z-Odin
PLZ: 6...
Beitrag von jeff-jordan »
jeff-jordan hat geschrieben:
Do 3. Okt 2024, 21:15
Das Dreamizer Teil (mit Angles Eyes) ist interessant.
Verkabelung sollte kein Problem darstellen, das kann man anpassen/optimieren.
Ich schau' mir das Teil mal an, mal sehen ob und wie das bei uns reinpasst bzw. was man von dem Ding verwenden kann... bei dem Preis kann man da nicht viel falsch machen.
Die Teile kann man leider abhaken. Sind im Prinzip wie 'ne Outdoor Taschenlampe mit Cree LED-Chip (deswegen auch dieses Highpower->Lowpower->Strobe Verhalten), nur dass man den Focus nicht einstellen kann (hab's zumindest nicht gefunden).
D.h. diese Zusatzscheinwerfer machen einen extrem engen und hellen Spot, aber damit kann man flächig nix ausleuchten.
Außerdem nehme ich den Dingern die "Wasserdicht"-Angabe schlicht nicht ab. Eine Fahrt im Regen und der Cree Chip säuft Dir ab.
Hab' die Dreamizer Spots daher wieder zurück geschickt.
Classico Li 05/2020 11 000+ km & Z-Odin 12/2021 31 500+ km :idea:
Zimmermännche
PLZ: 555
Mo 7. Okt 2024, 17:41
Danke für die Info. Bleibt also wohl nicht viel Auswahl, außer die Spots die Miguello, leider nur in Polen, gefunden hat.
E-Odin 3.0S 12/2022
Miguello80
Land: anderes Land
Di 8. Okt 2024, 21:03
Poland is not Antarctica :)
I promise, I will finish the video about new headlights this weekend so you will see how easy it is and how much difference :)
In case Autogamma do not send packages to Germany I can order it and re-send it to you, including all 3D printed parts needed for installation if you do not have 3D printer.
Zimmermännche
PLZ: 555
Do 10. Okt 2024, 00:09
Danke, ich habe den Shop mal über E-Mail angeschrieben und gefragt ob sie nach Deutschland liefern, was es kostet und ob Vorkasse möglich ist. Mal sehen was sie antworten.
3D- Drucker habe ich. Wenn du die stl.dateien bereitstellen könntest müsste ich mir nicht unbedingt was neues überlegen und konstruieren.
Aus was hast du deine Bauteile gedruckt, PLA, PETG, ABS, ASA oder mit Resin/Harz?
Halten die Teile den Temperaturen der Scheinwerfer stand?
E-Odin 3.0S 12/2022
Miguello80
Land: anderes Land
Do 10. Okt 2024, 22:16
STLs is no problem to share :)
So far I did not notice any problem with projectors so I believe everything is ok, they are "locked" in place so they can not move. During winter I will open it to replace one (BMW) COB ring that has some spots in it, maybe I screw the outer 3D printed part too much and it put too much pressure on ring (but spots are not symetrical so pressure does not make sense) or it is just a defect from factory, I have spare ones so no big deal, at least I will check all to be sure that all hold in place.
I printed it with cheap PLA for testing purposes but as it fit I left it inside to be able to ride soon :) If I see any deformations, I will reprint it with PETG or ABS or ASA. Projectors have fans so I am not worried that it gets too warm inside, there is plenty of spaces where the warm air can get off.
My biggest fear was whether the front plastic will withstand the heat from projectors but as long as you do not cover it it is ok. You can feel the heat on your hand because the light is reflecting but as it goes through the plastic, plastic does not warm up.
Zimmermännche
PLZ: 555
Do 10. Okt 2024, 23:52
Konntest du bei der Konstruktion nicht mehr die original Angel-Eyes benutzen? Diese sind ja auch nur vor die original Scheinwerfer geschraubt.
Welche Angel-Eyes hast du verwendet, hast du die auch von Autgamma?
Ich glaube Autogamma hat auch noch eine 1,8" Variante der Scheinwerfer.
Hat der12Volt DC Wandler hat mit der dauerhaften Leistungsabgabe für diese stärkeren Scheinwerfer auch keine Probleme?
E-Odin 3.0S 12/2022
Miguello80
Land: anderes Land
Fr 11. Okt 2024, 06:56
Yes, you can use original LED rings, but
1) I was not careful enough and wire disconnected from PCB on both rings, 2) it would be more difficult to adapt new bracket for old rings because of its construction where PCBs are not connected to the ring, they are held in place by the bracket 3) new rings are much brighter and look better.
New rings are COB LED rings, 60 mm, described as "for BMW", bought from 2 different e-shops, not from Autogamma.
No reason to use smaller projectors, 2" will fit.
No, DC converter does not have any problem with new projectors.
jeff-jordan
PLZ: 6...
Fr 11. Okt 2024, 21:39
Did you check a few minutes with high-beam?
Here I tested a 2,5" projector lamp and the solenoid that switches from low beam to high beam draw a little bit more than 0.8A at 12V. Which means two projection units will draw approximately 20W of power (that will be converted with 99% into heat)... even without the light emitting element (LED or Xenon light bulb).
Zurück zu „Dayi Motors“
