Tromox Mino
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Beitrag von vlad_vy »
Left Handle Switches
Deleted, see PDF file below.
Zuletzt geändert von vlad_vy am Mi 25. Jan 2023, 09:23, insgesamt 3-mal geändert.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Right Handle Switches
Zuletzt geändert von vlad_vy am Mi 25. Jan 2023, 09:24, insgesamt 1-mal geändert.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
All components of the main cable on one page. I hope nothing is missing.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Electrical diagram of the Tromox Mino main cable.
Tromox_Mino_main_cable.pdf
(207.39 KiB) 142-mal heruntergeladen
Zuletzt geändert von vlad_vy am So 18. Dez 2022, 09:20, insgesamt 11-mal geändert.
conny-r
Roller: E-ECONELO DTR 35Ah
PLZ: 36
Re: Tromox Mino
Beitrag von conny-r »
vlad_vy hat geschrieben:
Mi 7. Dez 2022, 18:22
Electrical diagram of the Tromox Mino main cable, draft version.
Danke für gute und übersichtliche Qualität. :)
Gruß Conny
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Added some corrections to the electrical diagram of the Tromox Mino main cable. It looks like this is the final version.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
It looks like OEM Lingbo LBMC 060122 HK3A EU M6 controller has not internal connection from the power terminal (+60V) to the pin 30, and pin 30 is powered from battery +60V over fuse 10A. So, if you use different LBMC controller, the +60V 10A fuse will be shorted and useless.
deadropine
Roller: Tromox Mino
PLZ: 8
Re: Tromox Mino
Beitrag von deadropine »
@vlad_vy
I am really fascinated how you have decoded all the wires and settings. Nevertheless do you see any chance to reprogamm the Lingbo Controller (60122)? There must be some way or equipement to do it? Where are the hidden settings and how can one get access?
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
I think it's almost impossible to reprogram an OEM 60122 controller. The only way is to read, decode, modify and flash the firmware again. But the firmware is protected from reading.
Main cable connectors
Main_cable_connectors.pdf
(443.26 KiB) 96-mal heruntergeladen
Left & Right Handle switches
Left_Right_Handle_Switches.pdf
(94.15 KiB) 76-mal heruntergeladen
Zuletzt geändert von vlad_vy am Fr 16. Dez 2022, 09:34, insgesamt 2-mal geändert.
vlad_vy
Roller: Tromox Mino
PLZ: 1
Re: Tromox Mino
Unknown free connector (near to controller)
Unknown connector pinout (viewed from rear):
   _~~_
1| = = |2
1) GND (12V, green); 2) +12V (yellow)
Zurück zu „Tromox“
