Falls Jemand zuviel Geld hat
Vahrland
PLZ: 0
Beitrag von Vahrland »
https://maxamps.com/products/li-ion-400 ... ttery-pack
Die Zahlen zu den Eigenschaften dieses Akkus sind ja doch etwas seltsam. Der Preis stellt aber alles richtig... 8-)
"Assembled in the USA
Li-ion 40000mAh 10S8P 36v Battery Pack
Price:
Regular price $2,240.00
Lifetime warranty
Lifetime USA customer support
ISO 9001, ISO 14001, NDAA compliant
Dangerous goods certified
Proprietary low temperature/high current MaxAmps assembly process
Factory fresh grade A cells
Voltage matched cells
Grade A pure copper wire(wire gauge depending on connector choice)
Silicone wire jacketing
Military grade assembly
Standard battery comes with Polyvinyl Chloride(PVC) outer layer
Your choice of connectors and wire length
Overnight shipping available
Brand MaxAmps Lithium Batteries
Capacity (milliamps - amp hours) 40000mAh - 40Ah
Nominal voltage 10S8P 36v
Maximum voltage 42v
Minimum voltage 25v
Recommended landing voltage(air) 30v
Recommended cut-off voltage(ground) 27v
Chemistry Lithium-ion(Li-ion)
Maximum continuous discharge 200 amps
Maximum charge current 40 amps
Watt hours 1440 Wh
Energy density 251 Wh/kg
Main lead length(custom lengths available) 5.5"(140mm)
Balance lead length(custom lengths available) 5.5"(140mm)
Length 8.3"(211mm)
Width 6.65"(169mm)
Height 2.95"(75mm)
Weight 201.97oz(5726g)
SKU Li-ion-40000-222-Pack
Available upgrades:
Hard case aluminum-rubber composite add between 5mm-15mm to length, width, and height and 5% to weight
State of charge indicator
momentary push button led lights
add 6mm to length and 10g to weight
Built in balance lead
built into battery, eliminates exterior wires on balance lead
add between 10mm-20mm to height and no added weight
Self balancing unit
balances individual cells in battery pack externally
no added weight or dimensions
DroneCAN adapter
bus communication
(150A Max)
Battery handle
Smoother transitions when removing from a platform
add 8mm to length, 2mm to width, 4mm to height and 35g to weight
Custom configurations, additional functionality, and engineered drawings are available upon request.
40000 10S8P Li-ion Data Sheet
40000 10S8P Li-ion Safety Data Sheet(SDS)
Lifetime Battery Warranty
MaxAmps offers a one-time, non-transferable lifetime warranty on any battery with a factory defect. Batteries that fail from improper storage or a use error are not covered. Replacements only apply to products purchased from MaxAmps and does not cover any other loss.
WARNING:
Do not charge unattended! The user must have an appropriate understanding of the potential dangers of lithium batteries before purchase and usage. No expressed or implied guarantee of compatibility, suitability, or fitness for any particular purpose or device can be made.
DO NOT USE WITH UNPROTECTED DEVICE
ALWAYS USE A PROTECTIVE CASE OR BOX FOR STORAGE AND TRANSPORT
BATTERIES MAY EXPLODE, BURN, OR CAUSE A FIRE IF MISUSED OR MISHANDLED
ONLY use with proper protection circuitry
DO NOT short circuit intentionally or unintentionally
KEEP AWAY from metal/conductive objects to prevent short circuiting
DO NOT use if battery, wrapper or terminal insulator is damaged or torn
DO NOT over-charge or charge above the maximum voltage rating
DO NOT over-discharge or exceed the continuous discharge rating
DO NOT modify, disassemble, puncture, cut, crush, or incinerate
DO NOT expose to liquids or high temperatures
KEEP AWAY from pets and children
ALWAYS charge in or on a fire-proof surface and never leave batteries charging unattended
ONLY use a smart charger designed for this specific type of battery
DO NOT mix and match brands and models, old and new, used and unused batteries
STOP immediately if while charging/storing/using the battery it emits an unusual smell, feels hot, changes color or shape, or appears abnormal in any way
It is your responsibility to determine that your charger or device is functioning properly
If exposed to battery electrolyte, flush with water immediately and/or immediately contact a physician or emergency services
DO NOT throw away in the trash; contact your local jurisdiction for proper recycling or disposal
Returns
If in the first 30 days, you are not completely satisfied, you can send your items back for a replacement or your money back. This does not apply to custom built batteries. You pay the return shipping charge and we pay for the replacement to be sent to you. Shipping lithium batteries can require certifications. Contact a local dangerous shipper if shipping batteries back to MaxAmps. We will not accept packages that are not shipped properly. Damaged batteries or batteries without a return authorization will not be accepted and will be returned to sender.
Shipping Policy
For domestic US shipping, we ship via FedEx, UPS, or USPS. If you prefer a certain carrier, please specify in the notes on your order. We offer Standard 3-5 day shipping on orders to US locations. If you need it faster, we offer express 1-2 Day Express shipping. Contact us for Overnight shipping options. Because lithium batteries are considered dangerous goods, carriers do not guarantee overnight shipping, but they do offer it. In our experience, we have had a 90%+ success rate using overnight shipping.
For international shipping, we primarily ship via FedEx Priority but we also offer UPS Standard Ground to Canada. If your country is not listed on the website, we may still be able to ship to your country. You will need to contact us for a custom shipping quote. Be aware that our shipping costs cover postage and insurance on the package but not import costs such as duties, taxes, or broker fees.
Tracking details will be emailed at the time of shipment. Please allow time for the online tracking status to update.
We make every effort to ship within 24 business hours. If you need your order to arrive by a certain date, be sure to contact us directly and we will do our best to satisfy your request. For possible lost in transit shipments, please contact us immediately so that we can contact the carrier.
Some batteries must be shipped as fully regulated dangerous goods and will arrive to you with a 30% charge. We recommend charging up to 60-70% shortly after receipt. In addition, our lithium batteries have passed UN38.3 Testing making them safe for transport. This test summary can be viewed/downloaded via this link if needed.
Privacy Policy
This privacy policy discloses the privacy practices for (www.maxamps.com). By using our site, you consent to this privacy policy.
Information Collection, Use, and Sharing: We are the sole owners of the information collected on this site. We only collect information that you voluntarily give us via email, through ordering and/or registering, or other direct contact from you. We will not sell or rent this information to anyone. We will use your information to respond to you regarding the reason you contacted us. We will not share your information with any third party outside of our organization, other than as necessary to fulfill your request, e.g. to ship an order.
Unless you ask us not to, we may contact you via email in the future to tell you about specials, announcements, or changes to this privacy policy. You can do the following at any time by contacting us via the email address or phone number given on our website: see what data we have about you if any, change/correct any data we have about you, have us delete any data we have about you, or express any concern you have about the use of your data.
Security: We take precautions to protect your information. Wherever we collect sensitive information, such as credit card data, that information is encrypted and transmitted to us in a secure way. You can verify this by looking for a closed lock icon at the bottom of the page you are on, or looking for “https” at the beginning of the address of the web page. While we use encryption to protect sensitive information transmitted online, we also protect your information offline. Only employees who need the information to perform a specific job (for example, billing, customer service, or shipping) are granted access to personally identifiable information. The computers and servers in which we store personally identifiable information are kept in a secure environment.
Cookies: We use cookies on this site. A cookie is a piece of data stored on a site visitor’s hard drive to help us improve your access to our site. For instance, when we use a cookie to identify you, you would not have to login a password more than once, thereby saving time while on our site. Cookies can also enable us to track and target interests of our users to enhance the experience on our site. Usage of a cookie is in no way linked to any personal identifiable information on our site.
Links: This website contains links to other sites. Please be aware that we are not responsible for the content or privacy practices of such other sites. We encourage our users to be aware when they leave our site and to read the privacy statements of any other site that collects personally identifiable information.
Updates: Our Privacy Policy may change from time to time and all updates will be posted on this page. This policy was last modified on 12/20/19.
If you feel that we are not abiding by this privacy policy, you should contact us immediately.
Terms of Service
User Agreement: This agreement is governed in accordance with the laws of the State of Washington. All users agree, through the use of this website, to the terms and conditions contained on this website. User hereby agrees to the exclusive jurisdiction in accordance to the courts of the State of Washington and any federal jurisdiction for any and all litigation. Please review all additional policies, such as the Privacy Policy, Liability Policy, Returns Policy, and Shipping Policy posted on this page. MaxAmps.com reserves the right to change or modify these policies at any time without prior notice.
Copyright Protection: All content on this Website (MaxAmps.com) are copyright. Any other use of materials on this Website without the prior written permission of Maxamps.com is strictly prohibited. Maxamps.com is not responsible for any content placed online by customers, including such content posted to alternate social media forums and third-party websites.
Trademark Protection: Trademarks, such as Maxamps.com, are either trademarks or registered trademarks of Maxamps.com. These trademarks may not be used in any way, except by the express written permission of MaxAmps.com, that may interfere with the business process or credit of Maxamps.com. Other products and company names mentioned on this Website may be the trademarks or registered trademarks of their respective owners.
Website Liability: MaxAmps.com, nor any of its affiliates, owners, employees, and/or other representatives will be liable for damages arising from or in-direct relation to the use of this Website. This includes all information, content, materials, and/or products included within this Website. MaxAmps.com reserves the right to cancel or refuse orders at our sole discretion. Please contact us immediately if you become aware of any errors or discrepancies.
Show More
Payment & Security
Payment Methods
Your payment information is processed securely. We do not store credit card details nor have access to your credit card information.
security
Security Image
Li-ion 40000mAh 10S8P 36v Battery Pack Li-ion 40000mAh 10S8P 36v Li-ion 40000mAh 10S8P 36v Battery Pack Li-ion 40000mAh 10S8P 36v Battery Pack Li-ion 40000mAh 10S8P 36v Battery Pack Li-ion 40000mAh 10S8P 36v
info@maxamps.com"
Das ist ja noch schlimmer als die Angebote von Stricker, wie diesem hier:
https://www.kaufland.de/product/533599459
Stricker macht übrigens auch Ebay unsicher...
Zurück zu „Lithium Akkus“
