Altis Sigma
NeoPostBoy
PLZ: 79***
Altis Sigma
Beitrag von NeoPostBoy »
Altis Powersports haben ein Bike namens SIGMA:
Keine Ahnung wegen Europa!
MODEL HIGHLIGHTS
97.2V35Ah (3402Wh) Samsung 50S battery Cells (Greenway Battery Pack)
Charging time (20% - 80%): 2 Hours
22kw peak Hairpin Motor (Automotive standard)
Adjustable off-road air-spring suspension
3.5" TFT display with NFC feature
5 levels of regenerative braking
Headlight & Taillight (w/brake light) switch
Heavy duty disc brake
CST off-road tires
Standard: 533n.m torque (39T Sprocket)
MX: 601n.m torque (44T Sprocket)
** Delivery dates range between early December and early January.
CHASSIS
Weight (with battery): 88 kg
Wheelbase: 1285 mm
Front brake disc diameter: 260 mm
Rear brake disc diameter: 220 mm
Chain: 428H
Frame design: Aluminium alloy forging
Ground clearance: 300m
Seat height: 840 mm
Steering head angle: 26 °
Suspension travel (front): 200 mm
Suspension travel (rear): 85 mm with linkage
Rear Wheel travel: 200mm with linkage
Wheels: Spoked wheels with aluminum rims
Motor
Max. power: 22 kW
Torque:72 Nm
Battery: Lithium-Ion ALTIS PowerPack
Battery capacity: 35 Ah
Charging input: AC110V/112V12.5A
Charging time 20%-100%: 180 min.
Charging time 20%-80%: 120 min.
Cooling: Air cooled
Energy content: 3.402 kWh
Electric motor: 98V - Hairpin motor
Falcon
Roller: Benzhou YY50QT6
PLZ: 79
Meister
First Nation Indigener
Foundation Mitarbeiter
Re: Altis Sigma
Beitrag von Falcon »
geil :)
endlich mal ne geile trial :)
vg
