Good morning.
Is there a video, manual, on how to remove the rear tire from its position?. I have seen that the fastening is by a double nut and not a bolt that passes from one side to the other. Any procedure available?
Thanks and best regards
Rear tire/rim removal
- Roller: e-Odin 50Ah / 6kW - <5.080km
- PLZ: 764
- Miguello80
- Roller: E-Odin 2.0 6kW AMR
- Land: anderes Land
Re: Rear tire/rim removal
Check this - https://www.youtube.com/watch?v=IrLNwSK ... Adventures
Removal is simple, you can take notes/make photos what was where and how positioned, but there is only one correct way how to put it back correctly.
If you want to take rear wheel to a tire shop, you have to start with disconnecting phase cables from controller + hall sensor cables from connector's wiring.
No big deal, don't worry
