What is the distinction between Ninebot Max and Ninebot ES4?
Alex John
Roller: Razor
Beitrag von Alex John »
Ninebot Max has a scope of 40.4 miles (65 km). Then again, the greatest scope of Ninebot ES4 is 28 miles, which is 20 kilometers not exactly the Max, so the Ninebot Max will show ukilometrese limited time.
In contrast with ES4, Ninebot Max has a higher slope grade. For instance, Ninebot Max can ride a slope with a 20% inclination slant, yet ES4 can climb a slope with a 15% angle.
With regards to battery power, Ninebot Max improves score since it has a battery limit of 551 Wh, while ES4 has 374 Wh. It implies its battery is fit for giving a long scope of miles. Also, Max's battery charges 1 hour quicker than the ES4. In this way, Max can be exceptionally useful assuming you are in a rush.
In comparison to Segway Ninebot ES4 vs Max, Ninebot Max produces higher light result than ES4. The ES4 is outfitted with a 1.5 W LED, while the result is furnished with a 2.5 W LED, which copies its perceivability. Hence, Ninebot Max is an optimal decision in a permeabilityumstance.
Bikes rely vigorously upon their tires for equilibrium, speed, and solace. Max's self-mending tire is pneumatic, while ES4's tire is strong and non-pneumatic. In this way, Max can retain more shock on rough streets. Moreover, the Ninebot ES4's tire width is 8 crawls on the front haggle creeps on the back tire, though Max's tire breadth is 10 inches.
Zurück zu „E-Scooter“
