I can now give you a full 'root cause analysis' as I see it.
The issue is that not enough glue was used. Yes, I believe this is all it was. They were saving money on glue.
I will show you that there was only just enough glue to stick the edges, leaving a gap in the middle where the rim curves.
See this example;-
- WhatsApp Image 2025-04-03 at 18.33.27.jpeg (59 KiB) 545 mal betrachtet
This magnet was clean and shiny before removal on the 'outside'. There was no sign of any corrosion until it was removed.
So, what happens is that as the motor cools in a cold environment, condensation may form between the backside of the magnet and the rim (because the rim is the coldest interior surface in the motor so all the condensation collects there first).
This causes corrosion and the magnets lose 'cohesion', that is the strength between the glue and the magnet itself, because the plating that the glue is attached to just gives up.
I have tested the magnets in the slots and whether 'glued in' or just not glued, the force is barely different, it is as if once they are rusted then there is not really any glue left. They are just sitting in the motor.
Therefore, those two that were clunking in my motor simply moved!
The least rusted magnets are the ones that had the most glue. It is very simple. The glue stops water condensing and protects the magnet as an extra coating.
I think all Dayi e-Odin 2.0 motors will do the same eventually, mine was left outside by the previous owner so I have experienced it first.
The solution is to re-glue all your magnets.
If you do it before they rust, then it should stop them rusting at all.
I can't decide whether to glue the magnets the other way around, so (once I have cleaned them up) the rusty face becomes facing the stator, or whether to glue them as they were before now the plating has gone anyway and protect it with the layer of glue. My thinking is that if the damaged side (damaged plating) rust then they will touch the stator and be 'cleaned'. Or maybe they need the protection from the glue even more now.
By replacing 8 (or more) slots with the new magnets, I will have some spares so I can use the better magnets of the rest
