REVOLUZZER 45 (2.0) mit 1200 Watt und 45 km/h
LoWess - König der Friesen
Roller: REVOLUZZER Plus - Akku 30 Ah Lithium
PLZ: 26316
Re: REVOLUZZER 2.0 mit 1200 Watt und 45 km/h
Beitrag von LoWess - König der Friesen »
Tensor007 hat geschrieben: 1) Can it be left outside when it's raining?
2) What's the max height position of the seat?
3) I have 195cm/95kg so i was wondering, how well does it behave with a bit bigger people..
4) How long did you have to wait for delivery?
1. Yes! No prolblems with the 1.0 model and the motor of the 2.0 model works in the same way.
2. See answer of chewbaka.
3. Weight maximum driver and package: 150 kg - Length driver: So whatever, could be a big foot. :D
4. Circa 7 - 10 days
Ein liebes friesisch Tschüüs sagt der Lothar (LoWess)
Revoluzzer Plus mit Akku 48 Volt Lithium 30 Ah
chewbaka
Beitrag von chewbaka »
MEroller hat geschrieben:
chewbaka hat geschrieben:4. if we believe the latest news by eneway (importer) youn can get it within ~ 10 days.
In Germany...
jepp! thats right. i have no idea about delivery to ?????
Tensor007
Beitrag von Tensor007 »
Hallo, thank you for your answers :) i'm trying to decide between revoluzzer 2.0 and
cheaper Evo, but R2 looks more massive... :)
What about average autonomy of the battery.. Up to 60km? And speed... Around 40?
And.. Can someone post inside volume measurments of the
optional back case? Thanks!
Delivery is to Slowenien, hopefully won't be a problem...
Tensor007
What would you choose between Revoluzzer 2.0 and Bossman-s 45Kmh? :)
chewbaka
you want to have informations, that we do not have, either!
the first 2.0 versions will be delivered in the next days!
PLZ: 26316
chewbaka hat geschrieben:the first 2.0 versions will be delivered in the next days!
And the Forca Bossman-S 45 km/h not before end of june.
PLZ: 26316
Frilo hat geschrieben:Hallihallo - Kurzinfo:Der 2.0 ist langsam in Sicht,wird nächste Woche laut Hr.K. Ausgeliefert.Berichte dann.Große Vorfreude meinerseits.
Gruß...Frilo
Moin Frilo.
Inzwischen sind ja nu auch fast 2 Wochen vorbei, deshalb die Frage, ist er, der 2.0er, nun bei dir angekommen?
Frilo
Roller: Revoluzzer 2.0 / Akku 48 v 25 ah Lithium
PLZ: 8
Beitrag von Frilo »
Hallo
Leider noch nicht.hab gestern dort im Büro angerufen um zu erfahren
Das meine Zahlung eingegangen ist.hat ja keiner bestätig.
Laut der Angestellten sind die grad am schrauben(Blinker).die sind wohl später
eingetroffen als der 2.0 .So hab ich das verstanden.
Abwarten,Tee trinken...
Gruß...Frilo
Monty
Roller: Chopper x9/Revoluzzer 45 erste Lieferung 2015
Tätigkeit: Chopper x9
Bekennender CO2 Freier Fahrer. Selbst den Strom bekomme ich durch Windkraft.
48V 30AH Lithium-Akkupack
Beitrag von Monty »
So, meiner ist da.
Der Wermutstropfen, der Sattel wurde nicht mitgeliefert. Bin gespant wie er ist.
Chopper x9/Revoluzzer 45, Litiuhm Akku 60V 20Amper
PLZ: 26316
Hallo, kannst Du den 2.0 nicht mehr dem Sattel vom 1.0 probieren?
Zurück zu „Revoluzzer 20 km/h und 45 km/ der 2.Generation“
