S01/Mo: Telemetriedaten mit Traccar verwalten
S01, S02, S03, Mó
lorenzo.deluca
Roller: Silence S01
PLZ: ITA
Land: anderes Land
Re: S01/Mo: Telemetriedaten mit Traccar verwalten
Beitrag von lorenzo.deluca »
Hello, sorry to jump in, in English ;)
If you want, to integrate Astra module to Traccar, you can go through Home Assistant (with the private server, https://github.com/lorenzo-deluca/silen ... ate-server if you like ) and from Home Assistant I have developed a simple integration via yaml script to send GPS/battery/etc. positioning from HA to Traccar https://github.com/lorenzo-deluca/homeassistant-traccar
I did it this way and I think that integrating the scooter on Home Assistant is also more useful for creating automations, notifications, etc.. If you already have your own private Traccar server running 24/7 it's not a big deal to put Home Assistant on it too.
While actually for GPS tracking alone Traccar is definitely better than Home Assistant.
Hope this helped :)
Gerold
Roller: Silence S01
PLZ: 55*
Beitrag von Gerold »
This is not an option for me since I'm using FHEM instead of Home Assistant.
Sending the astra reports direkt to Traccar has furthermore the advantage that you can use the Traccar-Manager for sending cammands to the module. in this way you are able to start and stop the bike ore open the seat. Even a firmware uptdate of the astra module would be posible.
Zurück zu „Silence / SEAT“
Mitglieder in diesem Forum: Ahrefs [Bot], Herve21, wbdz14 und 18 Gäste
