The new batteries are LiNiCoMn as well. LiFePO cells are bigger than LiNiCoMn cells with the same capacity. They would not fit into compact battery packs like the new ones from Emco.
The new batteries and their integrated BMS will work fine with the Novax' controller, if you connect them via the mentioned "split box". Emco uses split boxes in all their scooters that can be equipped with two portable batteries, namely Novi, Nova and Novantic. In these scooters, the split box also implements overcurrent protection. However, I'm afraid the split box cannot be used for the Novax, because the Novax' motor has much more power (4 kW instead of 2 kW). You will need to build your own split box using components that can take higher current.
Unfortunately, I don't know the split box' design, because the split boxes used in Novi, Nova and Novantic are moulded in epoxy resin, making it impossible to look inside. The split box looks like this (never mind the red arrow, it just points to a screw):
The simplest way to achieve a split box function would be inserting diodes into the minus lead of each battery, according to this (simplified) diagram:
- Splitbox
- splitbox.png (14.97 KiB) 5111 mal betrachtet
The plus connector of each battery is used as a common connector for charging & discharging. To split discharge current only, diodes must be inserted into the "minus discharge" leads. If you want to charge both batteries simultaneously, additional diodes must be inserted into the "minus charge" leads.
Pin assignment of 7-pin Weipu connector is as follows:
Code: Alles auswählen
1 + 2: Plus Charge/Discharge
3: Minus Charge
4 + 5: Data/Communication
6 + 7: Minus Discharge
For use in the Novax, the diodes should be capable of 100 Ampere current and to prevent overheating, they will need some kind of (passive) heatsink. Note that diodes will cause voltage loss of about 0,5 to 0,7 Volts. This results in a maximum power consumption of 42 A * 0,7 V ~ 29 W per discharging diode with both batteries connected and ~59 W with only one battery connected (it is not recommended, however, to operate the Novax with only one battery). To reduce voltage loss, use mosfets instead of diodes. Unfortunately, I don't have a diagram for such a circuitry.
Depending on the charger you want to use, each of the diodes used for charging must be able to take at least the maximum charging current, which is 15 Amperes when using an Emco quick charger.
The nominal voltage of the new batteries (48 V) is the same as the one the Novax runs on. So this should cause no problems. After removing the old BMS, you can connect the new batteries (via split box and overcurrent circuit breaker) directly to the controller's input.
Regards,
Michael
