A lot to read, thanks
Anyone knows what is the socket "fast charging" on the battery ?
Socket do not fit the charger. Inside there is a 250v mention ....
Thanks !
https://drive.google.com/file/d/1prBI0t ... p=drivesdk
That's exactly the problem that Sylvio has.... and it seems to be the same bms (look at his picture).dark_angel hat geschrieben: ↑Mo 17. Apr 2023, 14:28...
For the record, and others on the forum. My battery came from first batch on 2021.
Still have a 80v charge but do not charge again, the bms has Fried or something like that.
Hello! What is the bms you have put? Is it possible to change it using the same cell connections?dark_angel hat geschrieben: ↑Mo 24. Apr 2023, 17:02Hi,
it's probably the same problem as Sylvio.
Mine is clear, some components are fried![]()
First try to unsolder every one and solder new in place.
Really hard to unsolder even with a good soldering Iron.
Hard to find the same reference too ...
So I will replace the BMS by a New one, with bluetooth,...
Woah, sorry, but this looks awfull!dark_angel hat geschrieben: ↑Mo 24. Apr 2023, 17:02Hi,
error hat geschrieben: ↑Sa 22. Jul 2023, 02:34Woah, sorry, but this looks awfull!dark_angel hat geschrieben: ↑Mo 24. Apr 2023, 17:02Hi,
You have bridged the FETs with solder over the traces between source and drain. So it may work with no or little load.
It seems like you don`t know what you are doing.
Trust me, it would be a better way to remove the BMS completely, because due to the (accidentally?) bridged traces it wouldn`t be able to cut off anyway.
I bet these traces will melt or burn under load.
Please don`t post such pictures in an open forum and don`t try to convince others to do the same!
Kids, don`t try this at home!
SCNR!
