Votol em50 software problem
Muhammet
- Roller: Volta vs2
- PLZ: 61830
- Land: anderes Land
I have a votol em50 brain and I have a problem like in the video, even though I record it, when I turn it off and on, it still happens. Is there a solution for this?
https://youtu.be/FocsbJZgEOw
Re: Votol em50 software problem
Hello
If there is regulary function of the Votol-Controler, it switches to the status "Controller failure" (on display page), when the message "write to successful" is shown (correct function).
Can You see this change at Your Controller?
This "controller failure" means, that new settings are saved on a controller, which is still working on old settings -> failure.
If there is no display of "controller failure", Your saving of new settings was not successful.
After a successful saving, a restart shall load the new settings and delete the failure status.
Maybe this can help You, in Your search.
Muhammet
- Roller: Volta vs2
- PLZ: 61830
normally when my controller votol em 50 is connected to the computer, it opens as em 30 and gives a high path failure, I make em50 from the settings, I fill in the 0 places and save, when I exit and re-enter, it returns to its original state.
Mine (EM150s) returns to EM100 also (Firmware of EM100) but the changes of current and voĺtages stay on the new settings, after restart (if the values are in line with the model secifications).
VG
VG
Muhammet
- Roller: Volta vs2
- PLZ: 61830
It doesn't stay as I set it in my controller as in the video, it returns to zero. I took a backup before it broke down. I loaded the values. I close it and hurt it. It becomes zero again. It seems to shift but it does not work
What about status indication on display page?
Muhammet
- Roller: Volta vs2
- PLZ: 61830
sorry ich verstehe nicht was du meinst
Muhammet
- Roller: Volta vs2
- PLZ: 61830
friends this is the video of my controller does anyone know the solution for this
https://youtu.be/sERsjR-KkQc
Your video shows only page1. The display page screen Shows status of the controller. Maybe it indicates something at that time You switch off.
VG
VG
Muhammet
- Roller: Volta vs2
- PLZ: 61830
Although the controller is em50, it thinks itself as em30, so it gives a high voltage error on the screen page, but I upload the video by taking the video on those pages, but the problem is that the values I recorded are not saved, when I turn it off, it turns back to the old and this problem arose when there was nothing. I recorded many times while setting the sensor pain value, and finally it happened
