Miguello80 hat geschrieben: ↑Mo 13. Okt 2025, 01:44Hi, are you able to share detailed photos of controller boards ?
It is very small chance it would help with finding the solution of problem with impossibility to pair the motor with another (encoder) controller but it can not hurt.
(Yeah, I can not recommend Madatshop either, owner owes me money for returned wrong parts (his mistake)).
I am in contact with few guys in French that tries to make 3.0 motor work with 72680b, also some guy on this forum tried it (sorry, I do not have memory for names).
I believe it can be solved, as far as I know (I could missed it of course) nobody
1. checked encoder wires wiring = compare the factory pinout and 72680b´s pinout, there could be a difference that makes it impossible for controller to control the motor
2. measured signals from motor, especialy from encoder
I have nobody with 3.0 around so I am not able to dive into it, I have an offer of 3.0 motor for free, but it is in France and I do not want to pay lot of money for shipping when there is chance that I am wrong and the motor would be useless for me. But I am still thinking about it...
E-ODIN - Diskussionsthread
PO6EPT
- Roller: ODIN 3.0
- PLZ: 91578
- jeff-jordan
- PLZ: 6...
Danke Robert für die Fotos.
Welche Mosfet-Typen sind auf der Platine verbaut?
PS. Schade, dass die "Kühlpads" zerbröselt sind...
- Miguello80
- Roller: E-Odin 2.0 6kW AMR
- Land: anderes Land
I know I should write this in 3.0 thread but here is higher possibility that it will be seen.
Long time ago I talked with Hackey Babel, guy who invented and makes 3shul controllers. At that time I thought I will buy it instead of Fardriver but it is more expensive and not plug and play.
But I remembered that I asked him "Will be problem that my motor has an encoder ?" and he said no and asked some question, I sent him photos of wires and he answered this:
The encoder your motor have is ABI encoder
The pin out must be like this Yellow - A Green- B Blue - Z White should be for temp sensor and one other wire must be for PWM output
Typical abi encoder have A, B and index pulse
A and B are incremental output
The PPR thing
Wiring:
Yellow - hall u
Green - hall v
Blue- hall w
Purple : rc_pwm
White : motor temp
Red: 5v
Black: gnd
This is wiring on my 6kW AMR.
Can anybody confirm that his encoder wires are connected to correct pins on 72680b ?
Different wiring on 3.0 10kW AMR could be the solution for not working with 72680b.
The PPR thing
Wiring:
Yellow - hall u
Green - hall v
Blue- hall w
Purple : rc_pwm
White : motor temp
Red: 5v
Black: gnd
