Verschiedene Bremsen der Odin und Ihre Probleme
- Miguello80
- Roller: E-Odin 2.0 6kW AMR
- Land: anderes Land
Re: Verschiedene Bremsen der Odin und Ihre Probleme
Hi guys,
I measured both front brake discs and the left one is 2 mm out (on 1/4 of disc's surface gauge went from 0 to 2 mm up and then back to 0).
Right disc was only 0,02 mm out at one section. So at least one disc is ok (but I rather ordered two new discs https://www.cmpoparts.com/part/BRDF031 from e-bay, if it will colide with brake calipers I will handle it).
But I finally got to front brake pads and I can not find it anywhere else than in gran-scooter.com - https://www.gran-scooter.com/spare-part ... 20309.html (madatshop and xscooters does not sell it at all).
Does anyone know where can I buy it ? Or even better same dimensions (70x35 mm body / 67,7x31.6 mm pad) but different brand ?
These - Reeco RL8062 B6 114901 (for front brake calipers WITHOUT red "buttons"): I have found a lot of Reeco brake pads but none RL8062 (or rl-8062).
I am very seriously thinking about replacind brake rotors with some well known brand like Brembo etc. + make a bracket for it (then also will be possible to use bigger brake disc).
Thanks for any advice.
- jeff-jordan
- PLZ: 6
Hello Miguello80,Miguello80 hat geschrieben: ↑Mo 1. Apr 2024, 22:50...
look for brake pads for: "Hyosung 125 GV Aquila 2000", they are the same and will fit for our E-Odin 2.0.
Classico Li 05/2020 9 000+ km & Z-Odin 12/2021 19 000+ km
- Miguello80
I am affraid that these fit only calipers with red buttons, not in my HSK calipers, they are wider (77 mm).jeff-jordan hat geschrieben: ↑Di 2. Apr 2024, 12:27look for brake pads for: "Hyosung 125 GV Aquila 2000", they are the same and will fit for our E-Odin 2.0.
Do you see the difference ?
yours: my: I would be happy if I am wrong
- Miguello80
Hi guys,
to confirm my previous post I asked my friend with calipers with red buttons to bring me his front brake pads and compared it with my front brake pads, see the photo, and as I expected it did not fit my caliper. I found a seller on Aliexpress that says "official Reeco seller" so I contacted them and they answered that they do not have these pads in stock because they supply with them OEM manufacturers directly. After I explained whole situation they offered me a custom production. But one batch is 16 pairs Finally they said that they will make a small portion for aftermarket in less than a week.
Here is the link: https://www.aliexpress.com/store/818488 ... 2511cTPk5l - hope RL8062 will be there soon.
I also asked them whether they know where can I buy rear caliper because during brake fluid flush pressure valve broke off. (I did this many many times on my cars and other bikes and have a feel for tightening but this alloy is brittle as f..k. I am not used to blame anybody for my own mistakes.)
I am really fed up so I sent a message to Dayi through their website to www.dayimotor.com (I had to shorten it many times as the space is limited to around 1800 letters (it says 2000 but it is less in real)):
Hi, Leo left Dayi, now there is nobody who takes care of customers. Dayi Facebook page is full of E-Odin's problems but no reaction from Dayi.
I am from Czech Republic, bought 6kW AMR E-Odin in 8/2022. I am a member of large group of E-Odin owners from CZ and Germany. I run Youtube channel about E-Odin. I used to say "it has its imperfections but still good bike to buy". But now...
First brake fluid change after only 1200 km and pressure valve on rear HSK brake caliper broke off. I am skilled mechanic and I use a torque wrench, I would admit my mistake but this is absurde. Used alloy is very brittle, same as foot pegs. I will not mention brittle rear tile plastics and broken turn light indicators on every E-Odin I saw.
Brake caliper is impossible to repair and there is no place where to buy it! Spanish dealer Gran Scooter does not have even older version (with red buttons). German dealer Madatshop does not have it in stock at all. Polish dealer BiliBike has only older version (with red buttons, with brake lever) for 228 USD + shipping, that is nonsense.
Are you able to provide me with rear brake caliper ? Newer version, not with red buttons.
(I will continue in next message.)
Second problem - front pads in (newer) front HSK brake calipers, Reeco RL8062 B6 114901. No place to buy it! Reeco company offered me a custom production but one batch is 16 pairs. For older version you can use same pads as for Hyosung 125 GV Aquila but E-Odin owner with newer HSK brake calipers is done. I did not checked rear brake pads because one bolt is damaged from factory so I can not screw it off so I hope there is not the same problem like with front brake pads.
How is this possible ? E-Odins are still produced. It seems that Dayi's interest ends right after the sell, no aftersell support, especially when there is a lack of dealers.
Third problem - front brake discs. Warped, left disc up to 2 mm off and right disc up to 0,2 mm. Great. And none other brand fits.
I would love to make a video how Dayi solved those problems. Hope I will be contacted by Dayi and helped love my bike again.
I recommend everyone with problem do the same, lets wake them up !!!
Hope I will ride again soon.
- Miguello80
Uff, in the morning I checked again madatshop and miracle, they just added rear brake caliper (complete with left front caliper and left brake lever + hoses but what can I do), 127 euro, so I ordered it to be able to ride again soon.
But my path to change all brake calipers does not end.
By the way I thought about why the pressure relief valve broke off and my guess is wrong position of brake hose that pushed whole time on it and stressed the alloy. And also bad design etc. I should check it sooner Take it as an advice to check it too.
- Miguello80
Hmm, Madatshop sent me all three brake discs instead of brake caliper(s) so I am going to return it and I hope they will send me what I really need.
Damn...
Good news is that Reeco added brake pads for newer front brake calipers !!!
https://www.aliexpress.com/item/1005006 ... Redirect=y
Damn...
- Miguello80
Hi guys,
new bracket for new Brembo rear brake caliper is currently being manufactured so I will ride again soon
Next project will be... new brackets for new front brake calipers - of course Brembo
- Roller: Odín v2
- PLZ: A
Hallo! Sehr Was für eine Pinzette und wo hast du diese Stützen, haha
- Miguello80
Sorry, buddy, I do not understand what do you mean... Where did I get that brake caliper or bracket ? Bracket is my own 3D model based on factory bracket, differences is mounting dimensions, factory is 98 mm, new brake caliper is 84 mm. Is this what you were asking ?
